Rebekah_harper
Single click printer switching function
I have found myself with two different printers.
I was hoping that you could add a menu to the left side bar where the user could add printer profiles.
have a scroll bar for the list and a select option that allows a user to select the printer to be used, the work area to adjust accordingly and then continue as per normal for the printer.
I am thinking that a user could first use the config assistant and once accessed the user could use an add printer function to add it to the quick access list.
possible an exclusive tick box or something of the sort.
many thanks
Rebekah
