spasticken
Does anyone know how to end print job?
Hello,
After my print job finishes, I would like to have the printer do a few things, turn off fans, Z axis +10.
So far all I can find are absolute G code commands to move the Z axis, is there a command that I can use to make a relative Z axis move?
Also, is there a command to turn off the cooling fan running on the extruder?
Thank you in advance,
Ken
spasticken
Re: Does anyone know how to end print job?
I suppose I should add to this I believe that M107 RR will turn the fan off, but is there a way in simplify to test this, or how do I add it to the post print procedure?
I am a complete NEWB to 3D printing and am trying to get my stuff together.
Sorry if this has been asked and answered before.
Ken
glsf91
Add in Tab Script inder Ending script.
I use this:
G91 ;set relative positioning
;G1 E-1 F300 ;retract the filament a bit before lifting the nozzle
G1 Z10 ;lifts the nozzle off of the print
M106 S0 ;extruder fan off
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 ; disable motors
Second line is commented out for this moment
spasticken
Thank you very much!
