erniehatt
Frustrasion
The more I get into this the more I become frustrated with it all, if I had not spent so much I it, it would end up in the trash can.
Every turn I take summons up a different problem, I won,t bore you with all the details, just the present one, hopefully the last.
I printed a test 20x20x20 cube, turned out to be reasonable except for size, Z was close, X and had differences, I adjusted the X and Y E steps, and tried to reprint the cube only to find the Z axis traveling at less than snail pace, tried another driver but no difference, maybe dud drivers.
Anyone had this problem, better still anyone know the cause.
Thanks.
WizarDru
Re: Frustrasion
I feel your pain. 3D Printing can be VERY frustrating, especially when you see what LOOKS like everyone just effortlessly printing and you can turn anything out. I spent literal months dialing in my settings and periodically I STILL find things kind of goofed. But I have experience now and can rebound.
I'm not quite sure what you mean by 'Z was close, X and (Y) had differences'. Maybe a picture to show what went wrong?
Can you let us know your make of printer, as well? That might help us guess what the source of the problem is.
erniehatt
Re: Frustrasion
I can try to explain myself better.
Measurements after printing height 20mm Width on one side was 19.8 and the other was 2.1, OK that is fixable in Marlin which I did.
That is not problem, what happened afterward is, The Z axis was only moving very slowly in fact I was almost unable to see it move.
I tested things out by swapping Cables and Drivers which proved that they were working just fine, So the problem lies in either Marlin, maybe I altered something accidentally, or with the control board.
erniehatt
Re: Frustrasion
I found the problem, a tiny little typo, enough to send any man to the funny farm
Would you believe a Comma instead of a Fullstop. Hypercritical figures. 80,78,56,4000,837.00
