ststulsa
Cannot Get Model To Process for Print
Cannot get this model to process for printing. The program gets stuck at about 20% after I select "prepare for print." I am trying to print it solid w/ a .4mm nozzle at .1500 layer height. This is actually half of a part. I took the original part and cut it in half creating two separate .stl files. The other half had no issues making me think that the model itself is ok. I even tried changing to 15% fill at .2500 layer height to see if it sped things up and same issue. I have let it sit now for 20 min and it is still stuck at 20%. I have multiple computers with Simplify 3D and have tried this model on all of them with the same problems. Help!
1476983-3_No_Gaps_Top.stl
(1.66 MiB) Downloaded 205 times
Re: Cannot Get Model To Process for Print
i tried it on both my mac and my win10 machine. sliced on both in well under 10sec.
Similar results for me......less than 10 seconds. I did try slicing with a layer thickness of 0.05 mm and it took about 3 minutes to slice.
ststulsa
Strange - any idea why two different computers here cannot process the file to print??
Rebekah_harper
what's the spec of your PC.
ram, processor, graphics card etc....
ststulsa
Dell Latitude E5500
8GB Ram
Windows 7 Pro 64 Bit
Intel Core I5 5300U 2.3 GHz
Intel HD Graphics 5500
ststulsa
So it gets stuck on looking for overhangs. Any ideas??
