stormtrooperguy
Raise Z axis when print is complete?
I've just recently gotten my printer working, and am very very glad that I opted to use Simplify3D over the bundled Repetier-Host.
There's one oddity that is probably me missing something... When the print finishes, the extruder just sits at the last spot, and ends up solidifying / connecting to the model.
Is there a way to tell it to raise Z 10mm at the end?
Thanks!
Brian
Re: Raise Z axis when print is complete?
To raise the Z axis by 50mm, just add the following commands into your ending script (on the Scripts tab)
G91 ; use relative coordinates for jogging
G1 Z50 F1800 ; raise Z by 50mm at 1800 mm/min
G90 ; switch back to absolute coordinates
Vega77
Thx i will try that on my next print
stormtrooperguy
CompoundCarl wrote:To raise the Z axis by 50mm, just add the following commands into your ending script (on the Scripts tab)
Awesome, thanks so much!
