I'm trying to print this http://www.thingiverse.com/thing:620394 (the IKEA_light_beam_holder_push_mount.STL). I'd like to rotate the object around X by 90° so that there are no overhangs, but then the tag at the back doesn't appear on the sliced object (or the printed object)
Anyone know what setting is causing this? I sliced a very similar clip with Repetier many months ago without problems.
The skirt looks correct
I had the same problem with this http://www.thingiverse.com/thing:1065179 this morning, but I thought it was because I'd set the wrong value in OpenSCAD for the WallWidth
John
