Vega77
Raise z axis after finished print
If im not present when the print finishes, the z axis stays where the print ended.
After a short time theres a little area that becomes brown cause ot the heat.
Is there a way to make the z axis move a certain amount in pluss direction after a finished print ?
Re: Raise z axis after finished print
This was literally the topic right above yours: viewtopic.php?f=8&t=4834#p20924
Might be good to search a bit first ;)
