running a CTC replicator knockoff with a build platform of 220 x 140 x 150.
My origin offset is set to the middle of the platform by default (110, 70, 0). I'm having problem describing the issue, but basically, it seems like when I start a print, the head moves to the back right of the plate (from my perspective) which I understand to be the Max position (220, 140) as far as S3D is concerned. Instead of moving to 0,0 (front left) to warm up, it moves to the center of the plate then will print only in the back right corner of the plate (and attempt to go off the plate to the right).
I feel like when it goes to the Max position, the x and y axes are somehow getting reset to 0 at that point so that when it pulls the offset, it looks like the center of the table is the origin instead of the front left corner. I'm not very good with G code yet, but looking at the first part of my script (default) I'm not seeing the reset. am I going a little crazy? For the record, when I print through Slic3r or Makerware, the machine behaves correctly. Sorry if this is confusing, English not my first language.
; **** Replicator 1 dual start.gcode ****
M73 P0 ; Enable build progress
G162 X Y F3000 ; Home XY maximum
G161 Z F1200 ; Home Z minimum
G92 Z-5 ; Set Z to -5
G1 Z0 ; Move Z to 0
G161 Z F100 ; Home Z slowly
M132 X Y Z A B ; Recall home offsets
M135 T0 ; Load right extruder offsets
G1 X-110 Y-70 Z30 F9000 ; Move to wait position off table <-- at this point the extruder moves to center of table instead of where i'd think the origin would be.
