bapro
Movement behavior
The absolute best feature introduced in V3, in my opinion is, avoid crossing outline for travel movements.
By using this I can turn down all the ooze control parameters under extrusion tab to a minimum which saves time and gives better prints.
Now there are some improvements that I think could be made.
1. It doesn´t work where there is two towers. Simplify seems to skip the detour sometimes or making it to small.
I would think that a minimum and a maximum detour should be used. And it would be good to if that was to be given in mm intead of a factor.
I think it would prevent some blobs and making it more foreseeable.
2. A choise should be made to allow the detour at other sections like support, prime pillar and oozs shield.
Thank you for great software.
frederiekpascal
Re: Movement behavior
which factor do you use and which printer you got? :)
