I added a heated bed plate to my Makerbot Replicator 2 and then altered S3D with these settings. http://3dprinting-blog.com/498-how-to-u ... implify3d/
The first print worked well and the plate heated up first. Now I am unable to get the plate to heat up. Nearly every time that I go to my Firmware Configuration settings S3D will have snapped back Replicator 2 default instead of Replicator with HBP. I will reset it and hit Save.
I added the GCode and I know that it has worked once.
The plate works because I can heat it up thru the control panel on the replicator.
Best!
S.Houtzager
