tonyno
Support Changes Based on Location
Seems like this is a bug...
Re: Support Changes Based on Location
My guess would be that you are using too large of a pillar size. Try using 1mm supports instead
tonyno
I guess my point is that it should not change. Those are manually-added supports.
Rebekah_harper
Ive seen similar with infill patterns.
I think that when processing before the part is accounted for, the entire build platform is theoretically covered with the support pattern the cropped according the part's requirement.
So the pattern of the support exists before the part then cut by the part like a cookie cutter.
rebekah is exactly right. the support system works on a grid. imagine a piece of graph paper that represents the pillar locations. how big the squares are is the pillar size setting. when a part of the model covers a certain % of a square it is activated and a pillar is produced. it will never be the same from model to model since it just doesnt work that way. when you manually place the support you are just telling s3d that you would like support in that location and to activate a pillar in the grid. it doesnt mean that ever pillar you place will give you support exactly like you have it laid out.
