SHoutzager
Heated bed plate settings acting squirrly on Replicator 2
I added a heated bed plate to my Makerbot Replicator 2 and then altered S3D with these settings. http://3dprinting-blog.com/498-how-to-u ... implify3d/
The first print worked well and the plate heated up first. Now I am unable to get the plate to heat up. Nearly every time that I go to my Firmware Configuration settings S3D will have snapped back Replicator 2 default instead of Replicator with HBP. I will reset it and hit Save.
I added the GCode and I know that it has worked once.
The plate works because I can heat it up thru the control panel on the replicator.
Best!
S.Houtzager
Re: Heated bed plate settings acting squirrly on Replicator
You probably have your process settings set to override the firmware configuration. So you need to make the GPX change directly in your process settings (on the G-Code tab).
You can learn more about this here: https://www.youtube.com/watch?v=NYPUAqT4UyI
SHoutzager
That did the trick, so far!
