My flashforge dual bot is shaking to pieced when printing fast. I'm on sailfish with accel on in the bot.
How does the 3sd creator handle the acceleration and deceleration?
Ah, but it can be set by sending G-codes at any time -- just DON'T save to EEPROM with M500. I modify accel in my start G-code in my basic FFF.jimc wrote:Not sure about the ff but my makergear m2 which runs marlin, all the acceleration is handled by the firmware not creator.
Sounds like you do not have acceleration enabled on the bot. You can enable it from the LCD display under Utilities > General Settings. The alternatives are that for some reason, GPX under the hood generated s3g and not x3g from the gcode. Or, you did not follow the setup guide for installing Sailfish (http://www.makerbot.com/sailfish/setup/). Do you see this same behavior with prints from MW or RepG? I ask that in order to tell where the issue may lie.davedfx wrote:My flashforge dual bot is shaking to pieced when printing fast. I'm on sailfish with accel on in the bot.
