I have a rocket I desgined. it is 240mm tall my print volume only goes to 125mm.
if I put this onto the print bed will the printer simply "stop" when it hits 125mm or will it keep extruding in a circle unable to go higher or worse TRY to keep going higher?
if it will just stop that would be perfect because then I could just drop the print "through" the print bed by 125mm and hit print again to print the top half and build them together afterwards. would be easier than making multiple STL files.
if it will not simply "stop" is there a way in simplify to truncate the object properly at 125mm? (or whatever the build height limit is)
?? thanks
