Just built an E3D BigBox, made a few prints... I use Fusion 360 to design, S3D to slice and OctoPrint to print.
When I get to Octoprint with a gcode file I load this and hit Print. The temp is set for the extruder correctly at 190oC but not for the 60oC for the bed.
I can set the bed temp from the BB front panel just fine but it would be simpler to have it already setup.
Should I be using OctoPrint to set the bed temp and not S3D maybe?
But if I can set this in s3D where to set it? The only ref I can find is if I'm sending the print direct from s3D to the printer........which isn't possible in my case.
