Milestone85
How to Copy Processes?
I am trying to make the exact same process (a copy) so I can do sequential printing on multiple of the same object. I know the only way for sequential printing to work is by having a process for each individual model. Problem is I hate having to create a new process for each additional model, is there a way to quickly COPY the process (right click copy would be awesome). It would just speed things up and make it less of a hassle.
TenKOhms
Re: How to Copy Processes?
I believe if you "add a process" it will be a complete copy of the previous process. If not, you could always export the process you want to duplicate, add a new process, edit the new process, and import the saved fff file you created for the process you want duplicated.
tri-lite
Click on any of your models to open the fff dialog box. In the bottom left, click on "Select Models". A popup window will appear listing all your models, and then you can click on "Select All" in order to have your fff settings applied to ALL your models. Is that what you were trying to achieve?
TenKOhms
tri-lite wrote:Click on any of your models to open the fff dialog box. In the bottom left, click on "Select Models". A popup window will appear listing all your models, and then you can click on "Select All" in order to have your fff settings applied to ALL your models. Is that what you were trying to achieve?
I believe the OP wanted to enable sequential printing
Milestone85
Yeah just a quicker easier way to do sequential printing, I can do it but manually i have to create each process and assign EACH model to its individual process. If u have 24-40 models, you can imagine how time consuming that is. Sequential printing saves time and also produces nicer prints when there's multiple models, i used it already and good results, I just generally hate having to assign each model to its own process its unbelievably annoying LOL
Milestone85
Does anyone know an easier way to assign processes to multiple models for sequential printing? (sequential printing requires a process for each sequential item) 40 models = 40 processes
severan500
I do not know whether it is still relevant, but the copying process is very easy, just mark the process and press ctrl + C and ctrl + P.
mr0ng
severan500 wrote:I do not know whether it is still relevant, but the copying process is very easy, just mark the process and press ctrl + C and ctrl + P.
Thanks for the tip. On my computer ctrl + V does the trick (instead of ctrl + P). Very helpful.
EFK3D
Was looking for exactly the same thing ! Thanks for the tip !
Johnm
It is Command +V on a Mac. It seems to copy and past as a new Process. Then just rename the process.
