However, I did run into something which is an interesting thing which is worth looking at. While printing this: http://www.thingiverse.com/thing:39682 for the spouse for V day I see something happening which is interesting. S3D changes speeds, I assume, based on tool paths and layer height... but, I found on the second layer the speed went WAY up. That's ok... but... it was too fast for the optimal temp for the spool of PLA I was using. The result was the layer did not fuse to the previous layer. Next time around I upped the temp assuming what I saw the speeds as... and shut off the downward fan and it worked ok... but ... Looking forward using S3D one needs to set the temps way up accordingly per layers... OK we can do that in the Process screens... but it takes a printer TIME to heat up enough to match the heat. Soooo.... I believe the only solution currently is to set the temp much higher for the whole object. Not ideal...
