I'm having problems with printing 0.1mm layered objects with infills that are collapsing or stringing. The infill layers are not bonding or parts are missing.
The outer walls are printing fine.
Layer height 0.1mm
Nozzle diameter 0.15mm . I use this setting based on a tip from the forum for fine detail printing.
Extrusion width auto
Default printing speed 4500 mm/min
outline underspeed 50%
I'm on Sailfish Firmware with Acceleration On
It looks like S3D is under extruding during infill at 4500 mm/min
I'm also having this problem printing at medium print quality settings.
