Hi everyone! I've had my FlashForge Creator Pro for a couple months now -- currently in grad school for architecture. We do a lot of test models with our printers and I'm typically always using white; however, for our final models, I wanted to use the dual extruder to do two different colors. I've tried to set up the print several times and each time it's failed right after the raft is complete. It seems I can't upload .stl files here -- what works best for a closer look?
I'm using Hatchbox 1.75mm ABS in both white and silver. So far, the silver has only worked somewhat successfully on a small print where I tested the dual extrusion. This is house printed at 3/32" scale, so it's not enormous, but it's not small. I have the silver set as the outside envelope of the house and the white as the inside. I also set up supports and raft to be printed with white. As I mentioned, the raft goes on fine and then once the silver starts, it doesn't adhere to the top of the raft. I usually run the following settings for the white, and tried this and a couple others with silver, but no change:
Bed temp: 115C (tested at 110C as well)
Right extruder (white) temp: 235C
Left extruder (silver) temp: 235C (also tried 230C and 215C)
I'm so frustrated and really want this to work -- surely it's capable? Please help. TIA!
