Printing with wrong nozzle size!
Now here's something I did accidentally yesterday.
I needed to do a quick modification to one of the houses for the model railway layout I'm building......so I modded the design in my CAD package and exported it as an .stl file. I opened S3D and loaded a factory file for a similar house and then replaced the model with the newly modified model, generated the gcode to SD card. I then loaded the SD card into one of my printers....and it printed.
At this point, I realised that I'd used a profile designed for a 0.4 mm nozzle.....and I'd printed the model on my printer that had a 0.2 mm nozzle. "Whoops." I thought....and removed the model, expecting to have to chuck it and re-print on the other printer. But, wait a minute......a perfect print! Apart from a whisker or two around the roof and one of the three chimney pots, that is...which I expect anyway!
Now we're talking about a small print here (22 mm x 14 mm x 21 mm)...but am I just plain lucky this model printed, or are settings not that important after all?? :shock: :shock: :shock:
Heutinck
Re: Printing with wrong nozzle size!
That is interesting. It may be able to print, but are the dimensions accurate or is the model half the size? I could see if the extrusion width was set to a larger value than the nozzle width to compensate for the reduced nozzle, but you said it printed perfectly. that's really odd.
zemlin
The printer is going to extrude the correct amount of plastic - since it thought the nozzle was smaller the plastic probably just got pulled into a thinner stream as the head was moving. Hadn't really thought about this before, but it does seem reasonable that it would still come out OK - I might expect some softer corners or slightly wavy perimeter layers running a nozzle 2x what it was supposed to be.
