i all, just what distance can be covered without support.
I have a model with a rectangular hole, dimensions 40 X 40 x 11mm it is in a vertical position, the filament needs to cross the 11mm, is that possible.
I understand there is something in S3D called Bridging, can someone explain how this works, and if it will work with this file. thanks.
