I tried inside-out, outside-in, wipe, coast, negative restart and so on...
Do you have any suggestion?
*** This issue happens in two different machines.
What did you try?Dougwar wrote:Doesnt help
Horizontal lines, it's hege, but only in the outer perimeter startdkightley wrote:And it would be really helpful if you were a little more helpful as to exactly what the actual issue is you're having problems with. Lines? Vertical or horizontal. Looking at your photos, I can see both!
You need to help us so we can help you!!!
Read my posts, lines in the start perimeters, its not z relateddkightley wrote:https://www.simplify3d.com/support/prin ... e-of-print
