I've got (almost) everything working ok now - tracked some of the problems to the poor USB ports on my laptop, using the desktop now...
The final problem is the extruder motor is not running (doesn't run during a print or respond to the jog command). I have swapped the wiring about so I know the motor does work.
I expect it's something I have missed or messed up in the gcode setup but I'm a bit stuck at the moment.
As ever all help gratefully received - so close as well, it's frustrating to see the print head doing it's thing but nothing coming out!
Thanks,
Chris
(Win8.1 + Prusa Mendel Longboat + RepRapPro Duet with V10 of the DC42 firmware)
