MrWayne
S3D drops custom profiles
Hi there...
I have noticed that Simplify3D is constantly now dropping the custom profiles I built. I am having to import them constantly now.
Any reasons..???
I have a Mac platform running 10.9.2.
Thanks..!!!!
dubtec
Re: S3D drops custom profiles
I have exactly the same problem, or at least I think I do.
Do you mean process? as I create different process for disfferent layer height and fill, and everytime I close program and reopen they disapear.
Should I create diffent profiles for this, if so I still need to create a process everytime I open the program?
kobi-s
Same on my MAC. I use now W7
Jakob
are you hitting the save button at the bottom? i am running the newest version of osx as well. if i hit save then shut down creator and restart it then hit the add button to make a process come up it will bring the same process and setting up i left off with. i dont ever have to import anything unless i want to completely change to a different custom profile.
MrWayne
Hi There...
Yep, I do that. And then come back to the application and all the profiles (5) are gone.
Odd....
so when your process window is empty after restart and you hit the add button and the process pops up what exactly is the process it gives you? its not the one you left off with? is it just one of the defaults?
MrWayne
JimC...
That's correct.
I prepare a print, shutdown S3D, and when I next use it, hitting "Add" just asks to select a profile. All my five custom ones are gone.
man thats weird. i dont get that at all and we are running the same OS. dont know how i can help you there
