Like to see a variable retraction option.
If the travel path is less than 5 cm, the retraction will be 1mm
If it is between 5 cm and 10cm, it is 2mm.
etc.
Now I can only choose the best retraction on the largest travel path, which will give a perfect print, but the speed is slowed down due to the retraction. When the retraction is lowered for small moves, this will improve the printing speed.
