Does anyone uses the 3FXtrud 25 Duo (http://www.shapingbits.com/3fxtrud-25-duo/) with S3D? In case not, which preconfigured profile would you suggest as template to create the specific profile for this printer?
Not sure you have gotten your Shapingbits printer going or not. I finally received in mine and may test it out sometime this next week. Doesn't look like I can send a PM or if you have notifications active or not.
My home email is [email protected] If you got yours dialed in already, I wouldn't mind getting a copy of the profile export.
This weekend, I played a little with the printer and using Rigidbot Dual as the configuration worked well. Go to Help, then Configuration Assistant. Just need to adjust the extruder settings. I put Left as T0 and Left Temp as T0, and the Right as T1. And checked marked the Temperature boxes for waiting to heat up.
I did add some small scripts for turning off PLA fan when done, moving the platform down, and insuring the heaters were off.
I don't have the printer connected to the computer and print the from an SD card. The printer is a bit slow on its accelerations, compared to my faster Creator Pro movements. I may have to look into quickening that up some later on.
