Hi people!
I got a serious problem...
Every time i start a print the filament is retracted by lot of mms , this makes impossible to properly place the first layer...
I'm using a SmoothieBoard.
Any tips?
Nope! Just this:CompoundCarl wrote:Well do you have a big retraction in your starting script?
Everything seems to be ok in the gcode..CompoundCarl wrote:You can also open up your gcode file and look through the initial commands in the file to see if you see anything odd. [...]
Well.... this is not exactly a fix though :3PinballGeorgio wrote:Use a skirt with many outlines to see if the extrudings corrects
Don't get caught between a fix and a workaround!HexHyte wrote:Well.... this is not exactly a fix though :3PinballGeorgio wrote:Use a skirt with many outlines to see if the extrudings corrects
