I have not found a way to open an existing g-code file in order to make a change to the process settings.
There is no "Open" selection under "File" within Simplify3D.
If I click on a g-code within a hard drive folder, the file opens in 'save to disk" mode.
The file disappears when I then click on "edit process setting".
I would like to make only one small change to the process settings in order to track a change in one parameter rather than trying to remember how the process setting was originally set.
Your suggestions please...
Regards,
Ron
