I've been using this software a lot recently and I never seem to know exactly how much support material I need. I almost exclusively use Aquasolve PVA as my support material and PLA as my main build material. Due to the cost of aquasolve It is always a bad day when I plow through a roll only to have my print fail because I've run out and don't have more on hand. When I'm doing large builds that require a lot of support It gives me the total amount of material used. Unfortunately I've had to scrub builds because I started a print that did not start with enough support material.
Would it be possible to add a feature that allows you to see how much support is used as well as cost of support? As of the most recent update it only displays the amount and cost of build material used.
