HexHyte
LOT of retraction before printing process...
Hi people!
I got a serious problem...
Every time i start a print the filament is retracted by lot of mms , this makes impossible to properly place the first layer...
I'm using a SmoothieBoard.
Any tips?
Re: LOT of retraction before printing process...
Well do you have a big retraction in your starting script? You can also open up your gcode file and look through the initial commands in the file to see if you see anything odd.
If the gcode file is correct, but the printer is still doing weird things, then perhaps it's a firmware issue
PinballGeorgio
Use a skirt with many outlines to see if the extrudings corrects
HexHyte
CompoundCarl wrote:Well do you have a big retraction in your starting script?
Nope! Just this:
G90
M82
M106 S0
M140 S65
M190 S65
M104 S215 T0
M109 S215 T0
M104 S0 T1
G28 ; home all axes
G1 E-1.0000 F1800
G1 Z1.442 F1200
; layer 1, Z = 0.242
T0
_____________________________________________________________________
CompoundCarl wrote:You can also open up your gcode file and look through the initial commands in the file to see if you see anything odd. [...]
Everything seems to be ok in the gcode..
However i noticed that this problem is only occurring when printing throught USB... So using an external SD is the workaround for the moment..
Thanks for your help!
HexHyte
PinballGeorgio wrote:Use a skirt with many outlines to see if the extrudings corrects
Well.... this is not exactly a fix though :3
PinballGeorgio
Don't get caught between a fix and a workaround! :)
