Very helpful!!
As Carl has said, you're not going to get a perfect curved under surface, however adding some dense support layers....say 2... with 100% fill will probably give you the best you're going to get.
If you don't have it set already, also try changing the Outline Direction (Layer tab) to Inside-out...and use 3 or 4 perimeters. If this compromises the surface finish further up the model, you may need to use two profiles; one for the lower section printing perimeters Inside-out, and the second for the rest of the model printing perimeters outside -in.
