Sorry for my bad english
I have à problem with à commercial stl
S3d see the piece as multiple pieces
In Cura, i have no problem !!
Any Idéa ?
Thank you
Best regards
I have tried to repaire it with netfabb (classic) it's not betterCompoundCarl wrote:I'm guessing that your STL file isn't a proper 3D solid. It looks like it has self-intersecting features. Either boolean it together properly or run it through a service like netfabb to repair it.
This solution work with certain stl.dkightley wrote:Alternatively, use the Separate Connected Surfaces option on the Mesh dropdown menu. Using it will generate additional items in the model list...which is normal, but the part should slice okay.
