Budi67
Missing some layers
Hello
I have a strange problem !!
It missing some layers.
It's the first time that it happens
I have already spent it on https://netfabb.azurewebsites.net/
Any Idéa ?
A big thanks
Budi67
Budi67
Re: Missing some layers
I have tried with "Merge all oultines into a single solid layer" and it's ok !!
But i lost the holes at the end of the canonn
Can you attach your factory file to a post so we can take a look at your setup, etc.
File==>Save factory file.
Budi67
Here's the file ==>
project.factory
(2.55 KiB) Downloaded 304 times
We need the factory file WITH the model.
Budi67
Oups, sorry :roll: :roll:
project.factory
(54.73 KiB) Downloaded 323 times
Wall thickness is your problem.
The wall thickness of the barrel in the area where it misses out the layers is below the width of a single extrusion. You'll need to reduce the diameter of the tapered bore at the end of the barrel so the wall thickness is increased.
Budi67
Thank for your answer.
If the translator makes his work, you recommand to modify the file ?
If yes, it's a commercial STL
