Did a search, hadn't seen this listed (at least any time recently):
(slightly edited wording below)
Would really like the ability for 'filament profiles' to be saved independent from the 'machine profile': Every filament has things that make it unique from others: Filament diameter, extrusion temp, bed temp, extrusion multiplier, cooling required. I find myself loading a saved (machine) profile into a process, then having to check my notes for a given filament, and change that process for the given filament. What would be great instead would be if you could generate a 'filament profile' for each of your filaments, and just point your process to that profile.
On a side note, Slic3r implements this exact concept via their 'Filament Settings' menu. And while I don't use Slic3r, it seems like a great feature.
