dejanr
Running simplify 3d on nixos linux distribution
has anyone tried, or is using simplify3d on nixos linux distribuiton?
I have managed to get close to all dependencies i could find, but i am unable to run it. It installs well but it fails to run, check my chroot env setup here:
https://gist.github.com/dejanr/f7b113b7 ... 2cde873a91
to enter this env, and run s3d i just do:
nix-shell
./Simplify3D-3.0.2-linux-installer.run
and then run it,
here is a strace from running it:
https://gist.github.com/dejanr/788ef390 ... 9e68801cfb
Any help is appreciated, thanks.
andrewk72
Re: Running simplify 3d on nixos linux distribution
Did it run correctly at the end of the installer? There's usually a checkbox that asks if you want to run it, and that has always worked for me on several linux distros
dejanr
It didn't run at the end, when i say run it after install is complete, it hangs, i also posted strace when i run it manually, not sure what dependency i am missing.
I am running nixos, with i3 window manager, and no desktop environment.
andrewk72
It's desktop software, so wouldn't you need a desktop environment?
dejanr
Disregard please, this was probably a wrong place to post it.
