The bolt protrudes from the center of a cylinder at the top and sits a half inch within the print with a half inch of threads protruding from the top when the print is finished.
I've used this method before and it's by far the easiest in my mindCompoundCarl wrote:I posted a longer explanation here: viewtopic.php?f=8&t=5420#p23421
CompoundCarl wrote:I would imagine that holds the bolts very well! Plus it probably helps the layers around it bond together better so they are stronger
