sorcerer
Retraction between processes
Hello Guys,
I wanted to ask if anyone experienced my problem in the past:
I wanted to print two models with different processes. I set up both processes equally (only different in shell count) and whenever the nozzle changes to the other model I want a retraction to prevent stringing. For the printing within a model I do not want retraction.
So I set up:
-> retract only when crossing open space on both processes
Unfortunately this gives me no retraction on the travel between both objects. If I set up both objects with the same process, It will do retraction when travelling between! No difference if sequential print or continous print with 2 processes.
Is this expected?
Best Regards, Thomas
Re: Retraction between processes
Try checking the "Force retraction between layers" checkbox.
sorcerer
Hello,
this is for sure working. But I do not want to have a retraction in every layer of my print when I am printing sequentially 20 layers of each object.
What worked is Setting: Retraction Minimum distance: 99mm and putting the objects with more than 99mm distance on the buildplate.
Then I will get no retractions on travelling within one object and one retraction when travelling between the two different objects.
Conclusion: => "Only retract when crossing open spaces" does not work when sequentially printing objects with multiple processes.
Best Regards
