kutukutu1
[ALREADY ADDED] Per layer options for all settings
It would be nice if the per layer calibration such as the temperature could also apply to all the setting. For example i have a part that at the bottom is thick and prints very well at a certain setting, but then after a certain layer the model is no longer thick and its series of small pillars. To get a better print on those small pillars new settings are required, but the settings are global which means i cant modify them for lets say layer 34 and on. Just a though from my latest print that is giving me trouble due to the pillars.
Re: Per layer options for all settings
You can already do this. Just use multiple processes. That let's you change any setting you want for different regions of the print
https://www.simplify3d.com/support/tuto ... f-a-model/
