3ntrlab
[ADDED] removal of default profiles
Why on earth I should get my profiles on the bottom of the list ?
If used doesn't have any of the default printers, why should he care to scroll them every time he needs to change machine behaviour ?!?
In a professional setting this is really an annoying thing.
Best Regards
Davide Ardizzoia
Professional 3d printers : http://www.3ntr.net
rsilvers
Re: Feature request: removal of default profiles
I would like to see the profiles handled a differently.
1 - Any profile should be removable.
2 - Rather than export and then import and then have to hit "save" to add a profile to the list, I would keep the import and export buttons so that we can email profiles to each other, but also just have a save button right there that stores a profile into the list. So:
SAVE REMOVE
EXPORT IMPORT
Also, profiles that I create should not have a visible .fff extension in the name.
And the Save at the bottom of the large dialog should not effect those.
Version 3.0 only shows the profiles you have requested. You can also easily click Remove and select which profiles you want to remove from the list.
