I have a Taz-6 with a dual-extruder. I like and use the flexibility to use the front extruder, back extruder or both.
The problem I have is the viewport/bed is based on the back extruder only (Toolhead 0). So in this setup here: http://imgur.com/urQu07X If I select the front extruder, the parts print 50mm closer to the front side of the bed. If I move the parts any closer, they will print OFF the front of the bed itself. Basically, the front extruder will print a gooey mess as it moves on and off the bed.
If there's an in-program option to fix this, let me know. Here are some suggestions:
1) The printer should never be allowed to extrude/print off of the bed. Full-stop. If both extruders are in use, and the extruders are 50MM offset, make the front 50MM of the bed unusable for printing to make sure I don't make a mess.
2) If the part is printed by the front extruder (Toolhead 1), show it to me accurately on the screen.
