gregthoman
Print "pauses" on SD or USB
After the first layer or so, the print will "pause". If I'm running in USB control mode, I can press pause and the resume and it will keep going for a layer or so. On SD, The printer pause and resume commands do not work. This problem just started after a brief hiatus of just a couple weeks. I don't think anything changed. Any thoughts?
Re: Print "pauses" on SD or USB
If it's pausing from the SD card, then it sounds like you either have a bad command in your gcode or something is wrong with your firmware
gregthoman
It's pausing regardless. But I will try updating the firmware on the printer. Thanks
