Evils
Detach Post Processing from Saving Dialog
I started using the post processing option to scp my gcode files directly to my OctoPrint server. Unfortunately it seems as the Post Processing option is directly attached to the save dialog which causes the save dialog to freeze and stay on top of everything till the post processing has finished.
It would be great if these two processes would be detach from each other so the post processing can happen in the background independently from the saving dialog.
