I think you might not be understanding what's happening here.... the "partial layers" that your video shows are only top/bottom solid layers under/over where the print is sloped in that specific area. This was being printed in addition to your one perimeter, not instead of.nerys wrote:I have confirmed it was intentional gaps. The slicer was trying to apply top and bottom layers to the arching walls of the single perimeter walls. These partial top and bottom layers were just that. Partial leaving entire section of a layer empty when it would then rise for another layer and have no support under the unprinted sections of the partial layers. I removed the top and bottom layers to seperate processes and the errant partial supportnlayers were eliminated. Ie a nasty bug in the slicer but relatively easy to fox sinxe tou guys pointed me to what was causing it.
Your problem is most likely that you're trying to print one perimeter only at too high of a layer height and not getting good layer adhesion because of it. This occasionally manifests as a gap where the filament curls inward because you're laying a cylinder on another cylinder and it's off center, so it's prone to not staying exactly put. Lowering the layer height will force the offset between print lines to be smaller as well as flattening each layer's perimeter more.
