I'm using a Reprap printer with Marlin Firmware.
When print a part with Simplify3D, the 2 first layer are printed perfectely. A third layer Z axis down instead of up.
This also happens if I slice with Simplify3D and print from the Repetier-Server the generated Gcode.
If I slice with Slic3D it works perfectly.
I think the error is created by simplify3D in the GCode/
Thank for your help
Christian
