I am trying to print the star wars shuttle (mars scuttle)
I have had no problem printing this on my replicator mini (though the wings never worked)
now that I have my maker select so finely tuned I wanted to try it again (and larger)
but I keep having a problem with the ventral fin. the fin is only attached to the bed by a very tiny amount with a pretty aggressive overhang.
the printer handles it fine but for one problem. the tip likes to warp. normally just cosmetic but simplify likes to gcode this so it STARTS from the tip when it prints each layer.
of couse the TIP is what is warping so in pretty short order the head crashes into that warped tip and knocks it off the print bed (I even GLUED it down and it did not help) eventually that seperate tip JOINS the rest of the body was hoping to get it to stick around till that point.
the small pic is the start the second is the result. this time it built on the sphagetting so I am letting it go but as you can see it still warps. this time I got luck and the tip warped up then down again so the head does not hit so hard when it hits the next layer. it might actually make it this time.
is there anyway for me to force simplify to start each layer of that component from the root instead of from the tip? this would not stop the warping but would stop the collision with the warp and stop it from knocking that bit off the bed.
