msaeger
Make it easier to print copies sequentially
I would like it to be easier to print copies of objects sequentially. As it stands now I need to import the object multiple times, then copy the process multiple times, then tell each object which process to use. I think I should be able to just say make six of these, use this process, and print them sequentially.
It's nice to have the option to use a different process for each object but if I am making multiples of the same part it's far too complicated.
fabreax
Re: Make it easier to print copies sequentially
+1 for the same feature called "Print one at time" in Cura
sloworks
+1, yes, this would make it so much faster to handle
