Anyone tried the new version with a Cube X? Wondering how much of the post processing I'll need to change...
Thanks,
Zack
Unfortunately someone updated the CubePro firmware to v1.14B before I took over. I will let you know about the filament, I am messing around with it tonight.jschneider89 wrote:What firmware is everyone using? Anyone using one of the newer firmwares and able to get around the filament counter?
I changed M240 from S1400 to S1000. It causes the extruder to skip steps from the beginning of the print. First extrusion is the purge M55x command and it skips at that point. M240 is definitely not XY acceleration settingrazster wrote:The M240 command looks like it might control acceleration stuff, but it's hard to be certain. May need to experiment.
