notcriminal
impossible Bridges
..i am wondering the second time about this problem.
Why Simplify do this?
It makes impossible to print.
mroek
Re: impossible Bridges
Does it help if you reorient the part (i.e. rotate it about the z-axis)? First try 90 degrees, then try some intermediate values, and see if it affects the slicing.
Without searching the forum, I do think this deficiency in the bridging algorithm has been reported before.
Try searching....and you might find a workaround suggestion that will work.
notcriminal
mroek wrote:Does it help if you reorient the part (i.e. rotate it about the z-axis)? First try 90 degrees, then try some intermediate values, and see if it affects the slicing.
i tried, the same problem.
thanks....ok, then i must search for the topic.
the solution of the support didnt help.......i have not put to processes together.....
notcriminal
hmmm, the support give me one answer, but i havent put two processes in the file.
but the support is sure that i did.
its fascinated...i paid for a software and it full of simple bugs.
normally the free software is like sinplify3d. and the paid is without bugs.
but simplify takes money and give not a minimal supportz.
i tried what the support said, but it dont work.
a-i am so stupid
b- the answers are not good enough.
....and, to say, search the forum...... is not friendly and social......its simüliyfy-style.....not human.....a human shows....
And that form of comment is insulting.....and asking NOT to be helped. :x
I'll say no more!
