Successful 3.0 version
Attempting connection at /dev/ttyUSB0...
RECEIVED: XSß%âÒ~TÀÂ騼qCµzx )miSPcJstart
RECEIVED: echo:Marlin 1.1.0-RC3
RECEIVED: echo: Last Updated: 2015-12-01 12:00 | Author: Replikeo i3 Dual
RECEIVED: Compiled: Jan 23 2016
RECEIVED: echo: Free Memory: 3105 PlannerBufferBytes: 1232
RECEIVED: echo:Hardcoded Default Settings Loaded
RECEIVED: echo:Steps per unit:
RECEIVED: echo: M92 X80.00 Y80.00 Z4000.00 E425.00
RECEIVED: echo:Maximum feedrates (mm/s):
RECEIVED: echo: M203 X500.00 Y500.00 Z2.00 E25.00
RECEIVED: echo:Maximum Acceleration (mm/s2):
RECEIVED: echo: M201 X2000 Y2000 Z20 E1000
RECEIVED: echo:Accelerations: P=printing, R=retract and T=travel
RECEIVED: echo: M204 P3000.00 R3000.00 T3000.00
RECEIVED: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
RECEIVED: echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E5.00
RECEIVED: echo:Home offset (mm):
RECEIVED: echo: M206 X0.00 Y0.00 Z0.00
RECEIVED: echo:Material heatup parameters:
RECEIVED: echo: M145 M0 H180 B65 F255
RECEIVED: echo: M145 M1 H240 B100 F255
RECEIVED: echo:PID settings:
RECEIVED: echo: M301 P22.20 I1.08 D114.00 C100.00 L20
RECEIVED: echo:Filament settings: Disabled
RECEIVED: echo: M200 D3.00
RECEIVED: echo: M200 T1 D3.00
RECEIVED: echo: M200 D0
RECEIVED: echo:Z-Probe Offset (mm):
RECEIVED: echo: M851 Z-0.25
Testing plaintext communication protocol...
Testing binary communication protocol...
RECEIVED: echo:SD init fail
RECEIVED: ok
Connected to machine!
SENT: T0
WARNING: CRC mismatch detected
RECEIVED:
SENT: M105
RECEIVED: ok T:20.5 /0.0 B:23.1 /0.0 T0:20.5 /0.0 T1:20.6 /0.0 @:0 B@:0
READ: áÜxáxØÄGO8Dm0z.2YÁ2Q8BJstart
READ: echo:Marlin 1.1.0-RC3
READ: echo: Last Updated: 2015-12-01 12:00 | Author: Replikeo i3 Dual
READ: Compiled: Jan 23 2016
READ: echo: Free Memory: 3105 PlannerBufferBytes: 1232
READ: echo:Hardcoded Default Settings Loaded
READ: echo:Steps per unit:
READ: echo: M92 X80.00 Y80.00 Z4000.00 E425.00
READ: echo:Maximum feedrates (mm/s):
READ: echo: M203 X500.00 Y500.00 Z2.00 E25.00
READ: echo:Maximum Acceleration (mm/s2):
READ: echo: M201 X2000 Y2000 Z20 E1000
READ: echo:Accelerations: P=printing, R=retract and T=travel
READ: echo: M204 P3000.00 R3000.00 T3000.00
READ: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
READ: echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E5.00
READ: echo:Home offset (mm):
READ: echo: M206 X0.00 Y0.00 Z0.00
READ: echo:Material heatup parameters:
READ: echo: M145 M0 H180 B65 F255
READ: echo: M145 M1 H240 B100 F255
READ: echo:PID settings:
READ: echo: M301 P22.20 I1.08 D114.00 C100.00 L20
READ: echo:Filament settings: Disabled
READ: echo: M200 D3.00
READ: echo: M200 T1 D3.00
READ: echo: M200 D0
READ: echo:Z-Probe Offset (mm):
READ: echo: M851 Z-0.25
READ: echo:SD init fail
READ: ok
Testing alternate communication protocols...
READ:
Attempting RTS reset and trying again...
Connection failed.
