MichaelErwin
Raise3D N2 Dual - Native Support?
Noticed that S3D 3.1 shows support for Raise3D N2 Dual. However still unable to get it to work yet.
So does anyone have your N2 Dual working natively with S3D 3.1 yet? If so would mind posting your Factory file here, or what you have successfully adjusted to get it everything working.
Understand the graphics on the touch 0.7.0 is not supported natively yet, so excluding that.
Thanks
-Michael
andrewk72
Re: Raise3D N2 Dual - Native Support?
My friend has the N2 dual and he's just using the stock S3D profile that's included. Hasn't had any issues and he's already done lots of prints with it.
If you're having a specific problem, I would post more details about it here if you want help (pictures, files, etc)
MichaelErwin
I've used S3D for quite some time with amazing success with my MB Replicator2 farm.
Using the default profile for Raise3D N2 Dual
Auto-Configure for Print Quality -> Medium
Auto-Configure Extruders -> Left Extruder Only
Notice that Left Extruder shows at Tool 1
I slice the model, preview looks great.
Save Toolpaths to Disk
Copy the test print.gcode to USB...
N2 shows build plate heating to 60 (ignoring for now)
Then Right nozzle heating to 210c
Testing temp, shows Right nozzle is heated up to 210c.
MichaelErwin
I have noticed that the Tools Index for the N2 Dual that installs with S3D 3.1 is wrong.
For Raise3D N2/N2+ Dual it should be:
Left = T0
Right = T1
Heat Bed = T2
Also need to fix it on the Temperature tab in FFF Settings.
I will make a simple as possible N2 Dual template, to work with R3D Premium Filament.
Speeds & spacing need adjusted as well.
MichaelErwin
Raise3D N2 Dual.fff
Updated Base Profile for Raise3d N2 Dual with R3D Premium Filament
(23.97 KiB) Downloaded 598 times
Started with default S3D Medium: currently printing on left extruder only for now...
Extruder
Left Nozzle Tool 0
Extrusion Multiplier 0.94 (for R3D Premium)
Retraction Distance 1.5mm
Retraction Speed
Layer
Layer Height 0.15
Top Solid Layers 6
Bottom Solid Layers 4
Outline Direction Inside-Out (selected)
First Layer Height 100%
First Layer Width 100%
First Layer Speed 50%
Temperature
Left Nozzle Temperature Identifier T0, Layer 1 Temperature 205, Wait for temperature stabilization (selected)
Heated Bed Temperature Identifier T2, Layer 1 Temperature 40, Wait for temperature stabilization (selected)
Cooling
Speed Overrides
(selected) Adjust printer speed for layers below 15 seconds
Allow for speed reductions down to 10%
Scripts
Ending Script
M107
M1002
M104 S0 T1
M104 S0 T0
M140 S0
M117 Print Complete.
G28 X0 Y0
G91
G1 Z20
G90
M84
Other
Default Printing Speed 2400mm/min
Outline Underspeed 40%
Solid Infill Underspeed 40%
Support Structure Underspeed 80%
X/Y Axis Movement Speed 6000mm/min
Z Axis Movement Speed 1000mm/min
Current Medium Setting attached
Note: This is just a base line profile, that uses the correct LEFT & RIGHT Nozzle Tool Index. Will continue to update
